Thread: CEL / dashboard display
    Jul 2007
    montreal
    Default CEL / dashboard display
    I just took the dashboard off to replace what I thought would be burned-out bulbs but the plugs themselves are missing! I guess I'm off to the dealer to get some plugs but before I do I'm hoping you could help tell me what I'm missing...
    My main intent was to get the check engine light working (I borrowed the fog-light plug just for now). Now that it does, I can't figure out the stomp test... I've gone through all the old threads and pretty much hammered away every way I can think of. (so much that my neighbour came out and told me 'it's never going to start if the starter motor isn't turning' lol) 5 stomps, ten stomps, slow stomps, fast, short, long, hard, soft, whatever the blasted thing just stays lit. There is also an annoying long chime after I have pulled the key, but I think that's because I pulled the oil pressure light plug.
    The other (less serious) problem is that the readout display, odometer, and gear dispay are extremely dim... i can't figure out where the light is supposed to come from... can you tell me what (A) and (B) are, and since we're at it, which sensor (C) is? Thanks so much.
    Nov 2005
    There's nothing missing but the bulb itself.
    They come in one piece with the "plug".
    As a suggestion, put a flash light through the holes to see what comes on.
    "B" points to a lever that closes the cluster. "Aus" means opened, and "Zu" means closed.
    Don't know about "C", sorry.
    Nov 2005
    I think the faint display means the thing's not all the way in. I currently have that problem on mine on part of it, because it's a little skewed in place.
    Jul 2007
    montreal
    Default reason for faint display
    Quote Originally Posted by BMWDriver
    the bulbs are the same for the display... in the older displays the bulbs for the led are inside the dashboard... you have to open it up as if you were replacing the capacitors - explained here: http://www.bmwe34.net/e34main/mainte...capacitors.htm
    i originally went in there because the haynes manual (still waiting for the bentley to ship! aaargh!) says there are batteries that will fail and i thought that was why i wasn't getting engine codes. i couldn't find any batteries in there though, and neither could my neighborhood electrician.
    changed the bulbs and the readout looks like new at least.
    still can't get my engine codes though .... i think maybe my kickdown switch underneath the accelerator is busted or jammed and maybe that is the problem. i'm going to have to replace the pedal too if i keep on kicking it like i have been.
    sorry for reopening such a trivial post... i'm getting better at searching the threads now, thanks for your patience all.
    Jun 2007
    Cheshire CT
    I've got the same problem, sorta. I've replaced my 179 ecu with a 150. Now my stomp gives me a code which makes no sense. Stomp (x5) and the CEL flashes once, then flashes again, then just stays on. I'd switch ecu's back, but it's two states away .
    Nov 2005
    I stand corrected. Actually makes more sense too. I was under the impression the LEDs were self-lit. Then again, this is 90's technology.
  1. Please Help - Dashboard Display Issue
    By realness in forum 5 Series BMW
    Last Post: 06-06-2007, 11:33 PM
  2. dashboard computer fault display
    By 540 touring in forum 5 Series BMW
    Last Post: 12-30-2006, 07:18 PM
  3. Phone removal and dashboard display
    By theonew in forum 5 Series BMW
    Last Post: 10-18-2005, 03:51 PM
  4. dashboard display message
    By bobd in forum 5 Series BMW
    Last Post: 06-26-2004, 07:32 PM
  5. HELP - Dashboard display not working
    By Scott E in forum 5 Series BMW
    Last Post: 04-19-2004, 03:01 AM
