Were they both M/E or was one */E/S ?Originally Posted by Blitzkrieg Bob
Btw, how the hell does M work on these boxes? I've never encountered one yet and was wondering how you force it to change in M?
Anybody know if there is an electrical difference between and 89 and a 90?
Swapped a HP422 from one 535 to another, and now the M & E don't work.
In my experience with E32s I remember the '89 had M on the button and the '90 did not, perhaps the other way around. Not much I know but there was a difference between the two cars. Perhaps just just how these examples were equipped.
Originally Posted by Ross
I think it's M & A, but the dash shows M & E
I have a 1990 535, I have A & M on the panel, E & M on the dash when I use the switch, and when I pull the shifter down to a lower gear it switches to S.Originally Posted by Blitzkrieg Bob
I've got german alphabet soup.
89's work like this...the switch has 3 positions, up for S, down for E, and toward the rear for S (think sunroof). 90s and up do away with the E because BMW figured everyone wants economy.
For 1989s, if you flick the switch in S, there's a delayed upshift in 1st, 2nd, and 3rd gears. there is no upshift to 4th, even if the lever is in D.
For all cars, if you push it to M, the tranny will start off in 1st, 2nd, or 3rd, and no shifting will occur. Yes, you can go from 0-60 in 3rd gear, but your torque converter won't like you very much. Strange enough, if you have it in M in Drive, it will go to 3rd.
Finally, for 1990+, if you leave the lever in Drive, it's the "new" E(conomy).
Hope that helps...I'm drawing my experience from having owned an 89 and 90 535ia.
_______________________________
1990 535iA Glacier Blue Metallic 114k
dude in S mode there is an upshift to 4th gear... around 6,200rpm before the rev limit...
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
thats how my 1990 535i is.Originally Posted by Bin_jammin
And how fast are you going at that RPM in 3rd?Originally Posted by bmwrp8
