Since the offset is the same, ET20, the additional width is equally split, 1/2" on inside and 1/2" on outside.
Paul Shovestul
Originally Posted by Russell
I am going from a 7jx15 et20 cross-spoke wheel to an 8jx17 ET 20 wheel. (OE style 32). Is the 1-inch greater rim width on the outside or some on the inside?
I plan to use 235x45x17 tires. It seems as if the clearance along the front strut will be a bit tight.
BTW, I will use hubcentric rings. I have plastic and metal. TIA
Paul Shovestul
I am running 17x8.5 with that same tire size with no rubbing. You should be OK.
FS: PBR Deluxe rear brake pads [new]
i have 17x9 and no rubbing, so it's good.
if you can, use metal rings, plastic could shake.
17x10 no rubbing.
you wont have any trouble with those widths,I have had 17 x8 and now have 17x8.5 with 15 mm offset(thats goes 5 mm outwardi think) and i dont have any trouble,thats with mtech suspension which is slightly lower than std
Gone but not forgotten
thanks That is what I thought as well.
I want your wheelsOriginally Posted by Macv
