check the main relays in the computer box area on the right side...check the relays for the comp.box.,and the fuel pump...check also if you have fuel delivery,if you have then check if you have spark...might be CPSOriginally Posted by Anton CH.
I think I blew a fuse while charging the battery. I glanced over the obvious fuses in the fuse box but the car still refuses to turn on. Cranks, but seems there is no fuel. Are there any other fuses hidden away?
FS: PBR Deluxe rear brake pads [new]
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Dont forget there's a bunch of fuses under the rear seat - and if you've accidentally shorted something out there's always the chance you've blown the in-line battery fuse.
From expirence,,, there is a 50 amp in line fusable link,in the battery compartment, that is somewhat hidden,and wrapped in black insulating tape.... check it
Yeah, I actually got it running. After inspecting all the fuses, relays, and the fuse in rear it started up. Weird....
