Results 1 to 5 of 5
Thread: Very OT: Need help removing Ignition Lock Cylinder on 2000 Voyager
    May 2006
    Hawaii
    Default Very OT: Need help removing Ignition Lock Cylinder on 2000 Voyager
    Since I get all my answers to my BMW questions here, I thought I would give this a shot.
    I am trying to remove the Lock Cylinder from our 2000 Chrysler Voyager. The Haynes manual says depress the switch underneath the cylinder and Oila!...but not so for me.
    History: There was an attempt to steal the van and so the key will not even fit into the cylinder. The whole part is fubard. The switch is in "run" since the thieves got it that far but did not know that I had disconnected the battery and was replacing the water pump at the time so it wouldn't start. So I was actually able to hook up the battery and van started. Anyway, I have done everything I possibly can to remove the frickin thing. Any help would be much appreciated.
    Friends Don't Let Friends Drive Stock
    Honolulu
    bring the car to my house after 08/30
    I'll pull the manifold the fix the valley tube coolant leak. I still have a set of plenum gaskets.
    It's a lot easier that pulling the front of the motor off, and we don't want to do that **** again...right?
    May 2006
    Hawaii
    Default I have to get it running first...
    Quote Originally Posted by Blitzkrieg Bob
    Since I f***** with the ignition yesterday, I can't get it to start again. Oh, and those two bolts that were left....connect the engine cover to the power steering pump. I found a loose nut behind the power steering pump as well, so it wasn't an optical illusion.
    When it was running, everything was smooth. All the belts lined up nice.
    Honolulu
    Default buy this
    May 2006
    Hawaii
    Default I think I will
    Wanna go look at it?
  1. Ignition Lock barrel removing?
    By buzz66 in forum 5 Series BMW
    Last Post: 04-30-2007, 03:56 AM
  2. E34 Ignition Lock Cylinder Replacement?
    By DaCan23 in forum 5 Series BMW
    Last Post: 07-19-2005, 07:52 AM
  3. BMA ignition lock cylinder
    Last Post: 03-14-2005, 12:36 PM
  4. Ignition switch & lock cylinder
    By Gordie in forum 5 Series BMW
    Last Post: 01-04-2005, 11:19 PM
  5. Can a new ignition lock cylinder be matched to my key?
    By mancini_mark in forum 5 Series BMW
    Last Post: 09-01-2004, 12:24 PM
