My ignition switch turns just far enough to release the steering lock, which is not far enough to remove the lock cylinder by this method.
http://evansweb.info/articles/2003/0...on-lock-barrel
I might need to replace the entire cylinder/switch/assembly.
BMW quotes this as three parts.
I removed the lower clamshell beneath the steering wheel.
How do I remove the upper clamshell and the steering lock assembly (which has the key cylinder on the right side and the switch with wires on the left side)?
CarlD trimagna at yahoo dot com
