Originally Posted by
nbeckius
The antifreeze/water mix really depends on where you live. 50/50 is the recommended in many areas. Remember the water does the cooling, the antifreeze just does what it's name implies and has very poor cooling properties.
I've never heard of going more than 60% antifreeze in a system and if you live in an area where you never see below freezing temps you can not use it at all and go 100% water.
Distilled or purified water is best as it prevents corrosion. 75 cents per gallon at the market and it'll make the cooling system function better.
Theres a reason auto makers recommend a antifreeze/coolant mix.
Recommending 100% water is not good advice IMO.
Antifreeze/coolant besides the obvious it raises the boiling point of water, it does not evaporate like water does, it prevents rust and corrosion, and it lubes the moving parts in the cooling system.
Thats why you want to flush the system periodically, as the additives get depleted after a couple years.
1991 525i M50 5 Sp.
N.California
