Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Urgent Help Needed Please!
    Maryland
    Default Urgent Help Needed Please!
    I woke up this morning and my car wouldn't start. I don't know much about cars so I opened the hood and snapped a quick photo of the engine compartment.
    To those of you with more experience than I have:
    Does anything look out of order?
    Honolulu
    Default looks fine to me
    Quote Originally Posted by Evan
    maybe it's the CPS, or main relay
    Apr 2007
    Ridgecrest CA
    make sure your battery has a full charge,the problem is that loose chain that you can see in the front of your engine.turn the ignition to the start position and crank the engine until it stops turning.this will give the automatic chain adjuster enough time to draw most of the chain into the engine where it should be. bones
    Quote Originally Posted by Blitzkrieg Bob
    RONG!!!! Quite obvious its a giant vacuum leak. Try a search next time, newb.
    East Brunswick, New Jersey
    Put the heads back into the block before cranking the engine.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Jun 2007
    Cheshire CT
    I think you're low on headlight fluid.
    Indiana
    A rear wheel alignment might knock that back into shape.
    Feb 2007
    GreenHills East-Philippines
    bump.... try cranking it straight for 10mins.. might start
    HID 5000k low 3000k fogs
    dynaudio seps. mc intosh amp
    Race logic TractionControl
    Reading, UK
    Blatantly this is a diff problem, probably seized. The resulting torque back up through the gearbox has caused your M40B18 engine to rip itself free of its mounts and is leaning towards the left side of the car, not the right.
    Honolulu
    Default What a bunch of blind douche Bags
    it's just missing the plastic engine covers.
  1. oil cooler needed urgent m50 auto
    By Lordsneldon in forum 5 Series BMW
    Last Post: 01-06-2009, 07:13 AM
  2. Urgent Help needed - '96 328is won't crank
    By J.DeFeo in forum 5 Series BMW
    Last Post: 06-28-2007, 01:57 PM
  3. Urgent Opinion Needed
    By Jehu in forum 5 Series BMW
    Last Post: 05-29-2007, 12:14 AM
  4. Urgent Info Needed
    By Fraz06 in forum 5 Series BMW
    Last Post: 02-10-2007, 06:34 AM
  5. Urgent Info Needed
    Last Post: 02-10-2007, 05:47 AM
