Results 1 to 10 of 11
Thread: Antenna cable routing
    Oldham, England
    Default Antenna cable routing
    Aftermarket CD works but radio reception is rubbish. Checked and there is no coax cable at the back of the radio. There is only an oblong socket with 10 or twelve small pins that I guess used to go to the amp. There is no power to the antenna amp (white wire) on the rear left c pillar but heated rear screen works fine. There IS a coax connection to the antenna amp. Can anyone tell me what route the cable takes and where best to pick up a live for the antenna amp? If I werent so ashamed of the PO's re-wiring I'd post pics
    Bay Area, CA
    Factory antenna is not powered. You might be overlooking the antenna cable, search deep behind the dash and around to find it.
    Greg Mannino
    Bay Area, CA
    Its not powered behind the radio.
    Greg Mannino
    Bay Area, CA
    should be gray wire.
    Greg Mannino
    Oldham, England
    Default Antenna wiring
    Quote Originally Posted by gmannino
    Thanks Greg. There is no amp or cd changer in the boot - just a stand alone Kenwood up front. My understanding was the antenna amp in the pic below should have 12V at the white wire (brown plug). You can see the coax connector is still in place but the other end doesnt arrive behind the dash. Real.oem shows it running up the left sill but it doesnt. Just trying to avoid ripping out too much carpet and trim
    Reading, UK
    Quote Originally Posted by whiskychaser
    The antenna is powered on all E34 models iirc...
    Try popping out the heater controls and having a rummage down the back - also If it's a RHD, try popping out the glovebox ceiling and see if it's coiled up on top.
    What kinda muppet was the PO?
    EDIT: You're sure it's not hiding behind other wiring inside the left panels?
    Oldham, England
    Default Phantom coax
    Quote Originally Posted by Ferret
    Yes its RHD. Looked in all the places you mention but it isnt there. Its still connected at the antenna amp end. But I didnt fancy taking out the rear seat back or the centre console to trace it down if I could avoid it. Its in for MOT so will have another look later. Think PO only liked James Last - I got a free CD with the car
    Oldham, England
    Default Update
    Lots of muttering and cursing later and I found the coax from antenna amp ended behind the panel where the jack lives. Of course thats the first place you look isnt it? Good news is that there was enough cable to re-route back to the dash and with a new din/iso connector my radio works great on am/fm/lw.
    Reading, UK
    Lol, what the hell was it doing in the jack housing?
    Oldham, England
    Default Coax? what coax?
    Maybe went to an amp or something. There are lots of pairs of speaker wire that come to an abrupt end in the same place. Very tidy Oh, and a four pin plug. Anyway I can listen to Radio 2 while I sort it out
  1. M70 V12 belt routing diagram
    Last Post: 11-01-2009, 10:21 AM
  2. Bumper/marker light cable routing
    By E34-520iSE in forum 5 Series BMW
    Last Post: 07-31-2009, 04:52 AM
  3. Fuel & vacuum hose routing, m30
    By gale in forum 5 Series BMW
    Last Post: 10-07-2007, 10:38 AM
  4. Routing a power cable from battery to boot
    By Shando in forum 5 Series BMW
    Last Post: 07-05-2007, 08:54 AM
  5. re-routing fuel lines?
    By cschollum in forum 5 Series BMW
    Last Post: 12-27-2005, 07:14 AM
