is the sunroof open?
non-stop, As soon as e34 is started vents blow at low blowing speed as though they are in the 1 position, when in fact they are completely off. Anyone...Any suggestions.
1989 525i Ghostly Grey
not sure but I think its your AC control module...but let see what others thinkOriginally Posted by patznu
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
No sunroof works fine and completely ope and closes ???Originally Posted by repenttokyo
Well now you are talking,Originally Posted by bmwrp8
because I do not have any refridgerant in the system and planned on testing compressor and all of the above.
what I mean is that while you are driving, the sunroof will suck air out of your vents, and there's nothing you can do about it. you will feel them blowing on you.
you won't be able to turn on the compressor without the system being charged with refrigerant. If you want to test it "dry" you will have to run current to it manually.
Please clarify... because as soon as the car is started the vents blow as though I have engaged the heat/ ac.... but controls are off and not in position for car to react.Originally Posted by repenttokyo
if it happens as soon as you turn the car on, then it's not related to the sunroof being open.
i had a car do this once because a vacuum line associated with the heater controls had come loose in the engine compartment - have you taken a look to see if that has occurred?
Thank you sir ... I will start there next!!Originally Posted by repenttokyo
I shall keep you posted!!!
