Ordered Oxford Green Metallic from them a couple of months ago to respray my rear bumper & front grille. Provide them your paint code and you're all set. Easy transaction & information on the progress of your order was good. I checked with a local body shop supply & that paint is about $100/quart, and I don't have the spray equipment, so this looked like a good option.
They had to mix the paint & mail it GROUND because it is an aerosol, so it took about two weeks from order to receipt from West Coast to East Coast. They provide you with two spray nozzels to choose your coverage pattern. I went with the one which kept the mist in a vertical pattern vs. a round pattern and it went on with no problem & dried fast. Color match was dead on and my shabby, sun-faded rear bumper looks great now. They give you detailed instructions as to how to apply & finish the job. I am a much better at mechanics than body work, but still managed to get the results I was looking for. One can did the grille & bumper, but just barely, with run retouching.
Keep in mind that you must use a clear coat after the base coat. I did not buy clear from them. I used Wurth instead, because I had it.
Bottom line is that I will use them again if I need more.
