Results 1 to 5 of 5
Thread: Drivers seat trouble
    WI
    Default Drivers seat trouble
    I left the window cracked open today and then it decided to start pouring cats and dogs outside.
    Came out to find part of the seat closest to the window, seat back, door arm rest wet. Not soaking wet. Estimate the window was open maybe 20 min while raining.
    Anyway, first the seat decided it needed to be all the way forward. Tried adjusting it, none of the power adjustments will work. The passenger mirror stopped doing its flip thing too when putting trans in reverse.
    Checked Fuse 42? under the rear seat. Its a 30A fuse. Fuse is good. Reinserted fuse and the seat moved forward a little more.
    Removed and replaced fuse again, now the seat moved all the way to the back.
    Obviously, its getting power. Any suggestions to getting the adjusters to work? Remove and blow dry the switches? Is there a seat control module or something which should be dried out?
    Any suggestions much appreciated. Its a bit of a stretch to fully depress the clutch now...
    Roswell New Mexico
    so the seat is moving by itself???
    i would figure that some water got into the switch in the side of the seat and is shorting making the seat move.
    or your car is haunted.....
    take the switch apart and spray in WD-40 (Water Dispersant formula 40)
    WI
    Yup. All by itself. Pull the fuse and reinsert and back comes the seat. Strange thing is none of the switches will work manually.
    I figure it was parked under a statue of St Josephs, so it couldnt have gotten haunted too badly.
    WD40 in the AM and we'll see what happens. I'm assuming i need to take apart all the control switches for the seat and the mirror adjusters.
    Quote Originally Posted by Dr. evil
    WI
    Default All well
    Left it overnight and things must have dried out enough that all functions work again.
  1. Trouble finding +12v switched under rear seat.
    Last Post: 04-21-2006, 03:59 AM
  2. how do i fix my twisted drivers seat???
    By tim s in forum 3 Series BMW
    Last Post: 09-29-2005, 07:51 PM
  3. i need a e34 drivers seat
    By toddz in forum 5 Series BMW
    Last Post: 10-25-2004, 06:29 PM
  4. Power seat trouble
    By casurfer911 in forum 5 Series BMW
    Last Post: 06-24-2004, 09:25 PM
  5. where can I get a new or used drivers seat?
    By James in forum 5 Series BMW
    Last Post: 05-05-2004, 10:57 PM
