If you did not torque the bushing bolts while down on the tires and loaded normally, you probably destroyed your new bushings. The bushing angle of play is based on the whole arm in the normal loaded position. If you tightened it down in the angle where it was jacked up you were basically trying to twist the bushing to the normal loaded angle, which unfortunately will stress it to the point of tearing. Just follow Bruno's instructions and everything will be OK. Noise when hitting a bump with followed by the shaking is normally due also to worn out ball joints.
Originally Posted by AllanS
