close enough
i ordered some hubcentric rings today at work. they wre supposed to be 74mm outside diameter and theyre not. Theyre 73.8mm OD and the inner diameter is 72.56. I know it isnt the exact size i need but will this make much of a difference?
Mark
1999 M3 Cosmos Black/ Black 78k
1994 540i Oxford Green/ Silver Grey Sold @ 133k
1995 M3 Arctic Silver/Black Sold @ 117k
1990 325i Zinnobar Red/Black Sold @ 115k
close enough
In the field of high-end aeronautics, this could be a problem.
0.2 mm is so small, it's close enough to a hair thread.
74mm could be the bore they are meant to fit into, therefore a .2 mm clearance is built into them. (You can't go size on size. ) Sometime things are named for what they are used for, not what they actually are....if you know what I mean.
Washburn
95 525iT
