Results 1 to 10 of 13
Thread: Steel or Aluminum Strut Brace?
    May 2006
    NH
    Default Steel or Aluminum Strut Brace?
    I think i aksed about this alooong time ago but Steel or Aluminum ? Which would you choose and why?
    1995 540i Manual build 1/95
    Roswell New Mexico
    aluminum....because of weight
    Albuquerque, NM
    Definitely steel, the difference in weight for a strut brace is trivial. Aluminum has approx. 1/3 the stiffness of steel for a given cross-section.
    gale
    May 2006
    NH
    10-4,thanks.
    baton rouge, loserana
    mmmm ugg say steel strong, strong good
    Fogtown
    Most aftermarket anti-sway bars are made of moly doped steels. My guess is that they have best mechanical properties. Might look into that.
    FS: PBR Deluxe rear brake pads [new]
    T·O·R·O·N·T·O
    I got the mason one for about $20 bucks (don't ask). Was a bi*ch to get on. Needed to shave a bit of the padding on the hood too of course.
    Seattle, Wa
    Default What did you get-How'd they work out?
    Jehu,
    Been looking at the Mason Engineering Strut Bars was wondering how the install went and how much difference they made.
    Jim
    Feb 2007
    New Forest, ,UK,
    I bought a cheap ali one,fitted the turret rings, fitted the bar,adjusted to length, then removed it and copied it in non-adjusable steel,what a difference! Found I could wind the turrets 20mm in so had a bit of a saga measuring cars to get the right distance, hell of a lot of variation between cars, up to 35mm!
    Aug 2005
    West Portland, OR
    Used Steel...
    Didn't use steel...
    Merkava FTW!
    EuroLux:. Private Detail
  1. Control Arms: Aluminum or Steel?
    By Scott C in forum 5 Series BMW
    Last Post: 06-15-2008, 06:51 AM
  2. strut brace
    By PageRussell in forum 5 Series BMW
    Last Post: 06-02-2006, 10:34 PM
  3. OT: Strut Brace?
    By Rob in forum 5 Series BMW
    Last Post: 05-16-2006, 09:14 AM
  4. Strut Brace -- Take a look
    By mholbrook in forum 5 Series BMW
    Last Post: 03-01-2006, 08:49 PM
