Results 1 to 3 of 3
Thread: Technical specs for the cam in the M30??
    Default Technical specs for the cam in the M30??
    Does anyone have the technical specifications for the stock M30 b35 camshaft?
    Bill - is this Boring Guy Stuff?
    I'm looking for the following:
    intake and exhaust lobe valve opening angles for 050 lift
    intake and exhaust lobe valve closing angles for 050 lift
    degrees of lobe separation
    not as important but interesting - max valve lift
    I'm assuming these are symmetric lobes, correct?
    Thanks!
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Default Nope, I don't have it in the boring guy stuff, but if you find out let me
    know too if you don't mind.... intake lift, exhaust lift, duration intake and exhaust, overlap exhaust, and they look like symmetric lobes to me... If you guys have a spare cam you could degree it out yourselves and meaure the lift and duration....All you need would be to mark off the cam gear in degrees, some v Blocks to set the cam in on a flat surface and a dial indicator that would measure in .001 inches up to say 1 inch of travel...
    Quote Originally Posted by Jeff N.
    Thanks!
    Jeff
    Default No spare cam...
    Someone's got to have them...I'll see what the UUCdigest guys might suggest for resources....
    Bellevue WA
  1. M60B40 technical specs for download
    Last Post: 03-18-2008, 11:01 PM
  2. Changing Euro Specs to US Specs?
    By brianwolf3 in forum 5 Series BMW
    Last Post: 03-06-2007, 01:18 PM
  3. Technical Advice please.
    By inkstom in forum 5 Series BMW
    Last Post: 12-16-2006, 08:50 PM
  4. BMW Technical Acronyms
    Last Post: 12-12-2006, 12:13 AM
  5. ZF 5HP 30 - technical bulletin
    Last Post: 09-26-2005, 03:03 PM
