Results 1 to 5 of 5
Thread: Right procedure for battery removal & jump starting
    Feb 2005
    Penang, Malaysia
    Default Right procedure for battery removal & jump starting
    folks, 2 separate questions:
    1. when removing battery, which should i disconnect first: +ve or -ve cable? how about when attaching the battery?
    2. when jump starting a car, which cable should be connected first?
    Mar 2004
    NSW, Australia
    Default negative
    Quote Originally Posted by ktteoh
    comes off first and negative always goes on last
    Q2. Connect +ive first negative last
    Wellington,New Zealand
    some people also recomend that the headlights etc are on I think to act as a "sink" for voltage spikes when you connect and disconnect??
    Gone but not forgotten
    Oldham, England
    If you remove your battery for charging be careful about locking your doors manually. You may not be able to open the again!
    Apr 2007
    Quote Originally Posted by mamilapon
    this is a question i wondered my self and had contradicting views on the internet. mine always sparks as i reconnect the negative with the hazard lights starting to flash....wierd.
    1995 m50 520i executive
  1. HELP! Z3 battery died, jump-started, car won't start
    By brandilynd in forum Z3/Z4 Forum
    Last Post: 05-27-2017, 07:03 AM
  2. Thrust arm removal...alternative procedure?
    By rizal in forum 5 Series BMW
    Last Post: 05-08-2007, 12:59 PM
  3. Headlight removal procedure
    By kngpen in forum 5 Series BMW
    Last Post: 12-14-2004, 03:26 AM
  4. Headlight removal procedure
    Last Post: 09-03-2004, 02:28 PM
  5. Headlight and Seat removal procedure
    Last Post: 07-18-2004, 08:22 PM
