Results 1 to 4 of 4
Thread: How much toe when getting a wheel alignment done
    Default How much toe when getting a wheel alignment done
    I've installed new upper and lower control arms and fixed camber plates, now I need a wheel alignment. I realise only a front wheel alignment is needed as there is no adustment for the rear wheels and only toe can be adjusted on the front wheels. I goto Kmart across the road from where I live and they said it would take over an hour to align becasue "I didn't tell them about the camber plates", well I said "they are fixed plates, there is no adjustment on them?". I'm wondering what marijuana they have been smoking????
    The bently manual outlines the toe settings as;
    Can you tell me what this means and give me a guide to how much toe I should ask for?
    El Paso TX
    tell em that much... about 7-9 minutes per side, for a total of 14-18 minutes
    7 if you autocross frequently, 9 if you drive daily.
    If they can't figure that out, then leave.
    thanks very much it's on h&r sport springs if that makes any difference. I realise the bently manual doesn't note those springs. I understand now, all the bently settings are saying 18 minutes +/- whatever...
    Quote Originally Posted by attack eagle
    El Paso TX
    Straight ahead toe requirement doesn't change with ride height, but the amount of toe that naturally occurs when the wheels are turned does. Thus the various specs depending on ride height.
    More toe = more stable, less toe = less stable/ twitchier.
    Just be glad you don't have to specify your settings for rear toe and camber like i do. Only place in town that will even touch mine is the Dealership. Everyone else is too afraid to touch it. Even the dealer is afraid to set it to some random number out of a book or computer when it isn't close to stock...
  1. Wheel alignment
    By Mas (UK) in forum 5 Series BMW
    Last Post: 03-28-2008, 07:19 PM
  2. e34 Wheel Alignment
    Last Post: 12-02-2004, 10:49 AM
  3. Wheel alignment result
    By kentish in forum 5 Series BMW
    Last Post: 09-05-2004, 12:38 AM
  4. Wheel Alignment
    By BennyM in forum 5 Series BMW
    Last Post: 03-25-2004, 06:35 PM
  5. wheel alignment inquery
    By Mike in forum 5 Series BMW
    Last Post: 02-17-2004, 07:14 AM
