Results 1 to 10 of 11
Thread: e34 535i Lowering spring rates needed please.
    Default e34 535i Lowering spring rates, GOT IT, car completed
    Hi Guys,
    What spring rates you guys have, either with the Eibach or H&R's sports package on the e34 535i?
    They normally have a set rate for their sport springs, just wanted to know what you guys are using for a street set up.
    Thanks.
    BMW, THE ULTIMATE FLYING MACHINE
    SPEED AND POWER IS NOTHING WITHOUT CONTROL,
    THANK THE GERMANS, BMW HAS ALL 3
    Honolulu
    Default got Eibach
    nice drop and a good ride
    Quote Originally Posted by Blitzkrieg Bob
    Sounds good. What shocks are you using?
    Thanks.
    Honolulu
    Default I have
    Quote Originally Posted by Turbo Ready
    Thanks.
    Billsteins in the front and boge in the rear.
    Front is a little stiff, but not harsh by any means
    Thanks for the info Bob
    Honolulu
    Default Some more info
    I am installing an Eibach lowering spring kit along with 4 Koni SA shocks on a 91 BMW e34 535i 5 speed sedan.
    Some information on Eibach Pro lowering springs for the BMW e34 EXCEPT THE ONES WITH THE M50TU ENGINE
    Listed below are the springs with the individual part numbers and individual spring rates.
    Eibach Pro (sport) springs
    BMW e34 (except for the e34 with the m50TU engines)
    KIT NUMBER (set of four) 2013.140
    Front (part # 2013.101) Rate 171 lb/inch Estimated drop 1.2"
    Rear (part # 2013.202) Progressive Rate 142-257lb/inch Estimated drop 1.0"
    We might upload some pics after completion.
    Feb 2007
    New Forest, ,UK,
    Are you absolutely sure on that 171lb/in?? Not exactly sure what a M50TU is but ny TDS works out 46lbs heavier on the front compared to a 535A,spring rates in the car at the moment are320/338lb/in and not stiff enough really.My next attempt will be a coilover conversion-dirt cheap-and 10" by 21/2 springs are peanuts, will let forum know what I end up with!
    Quote Originally Posted by Barney Paull-Edwards
    According to the tech support personnel at Eibach, 171 bl/inch for the front.
    Are you sure your numbers are not just ratings like H&R use? I know they use a different rating system, like the bmw e30 which is 650 front 475 rear, but this is not a lb/inch rating.
    Whose springs are you using?
    cool, are there other spring rate data available for other springs, eg h&r, stock, m-tech, etc..
  1. Replies: 1
    Last Post: 12-17-2007, 01:09 AM
  2. Lowering Spring Install Hangup
    By Evan in forum 5 Series BMW
    Last Post: 09-10-2006, 06:00 AM
  3. LAD -> Non-LAD Lowering spring question
    By AllGo'n'Show in forum 7 Series BMW
    Last Post: 04-24-2006, 09:05 PM
  4. Need help finding M-tec lowering spring part #s
    By ericcamaro in forum 5 Series BMW
    Last Post: 10-19-2005, 01:29 AM
  5. Anyone know the Spring rates for the H&R springs?
    By Anton CH. in forum 5 Series BMW
    Last Post: 08-26-2005, 12:41 PM
