Verify that both the switched 12volt and the constant 12volt power is at the radio and that ground is connected.
Paul Shovestul
Originally Posted by
Tder
I'm struggling to get my radio to come back to life after having disconnecting the battery several times over the winter. It's the Pioneer version MBZ-83 if memory serves, but I might be wrong.
The problem is that it won't prompt me for "CODE". This is suppose to be a security feature after 3 wrong entrys for the code, but as I understand it the radio should allow re-entry of code after being on for an hour with the Key in the number one position. I've tried this and also left it on with the key in the on/motor running position.
During my replacement of the heater core and disconnecting the battery again-it did prompt for code and allowed one attempt which it wouldn't except the code, and went back in to lock out mode.
Any suggestions or hints? Is this a known failure mode of the radio and do I need to get a replacement?
Thanks in advance,
Tom Der
North Hampton, NH
90 535i
91 M3
