Results 1 to 3 of 3
Thread: Periodic CEL and Oxy sensor codes after REPLACING both sensors
    Chicago
    Default Periodic CEL and Oxy sensor codes after REPLACING both sensors
    When I had my transmission replaced in December, I also had the mechanic throw on two new oxygen sensors that I supplied. Assuming that he installed them correctly, what could be causing the computer to still throw oxygen sensor #1 and 2 codes??
    The check engine light illuminates for a few hours about once a week now too. Any thoughts on this? Thanks in advance
    _
    probably has the usual intake leaks and or bad pcv plate, common v8 problem should come up with all the info you need with a search using the words intake leak and or pcv plate
    MAF too.
  1. testing+replacing oxy sensors on V8 engine
    Last Post: 01-19-2008, 11:55 AM
  2. Bad 02 setting off knock sensor codes?
    By 94530inh in forum 5 Series BMW
    Last Post: 11-26-2006, 10:00 AM
  3. PLEASE HELP! Need help replacing trans.. speed sensor
    By juan525i in forum 5 Series BMW
    Last Post: 07-28-2005, 05:41 AM
  4. Need advice in replacing Coolant Level Sensor
    By The Melmaan in forum 5 Series BMW
    Last Post: 11-11-2004, 10:26 PM
  5. Temp sensor probs after replacing battery
    By tracye34 in forum 5 Series BMW
    Last Post: 04-10-2004, 01:32 PM
