Results 1 to 10 of 17
Thread: My cylinder head... reborn...
    PA
    Default My cylinder head... reborn...
    So as everyone knows I bought a '92 E34 525i and am now getting around to building it. With much thanks to Jay (Multiplex) and his gracious use of cleaning machines and such, I am making this thing look like it never has before.
    Here are some pictures of how it looked about 6 hrs ago:
    Then, Jay and I tried out the soda blaster - for those not familiar (and I had never used one until today, though I researched it...) it uses essential sodium bicarbonate (baking soda), water, and air pressure. It's not an abrasive - it has more of a chemical reaction to hitting the aluminum at accelerated speed... people describe it in layman's terms as "exploding on the surface" so basically the soda breaks down as it hits, without ever affecting the finish... and so... this is what I was able to accomplish:
    PA
    and most importantly... the combustion chamber! Pay special attention to the valve seats! Freaking beautiful.
    I am going to spend time removing the residue from headgasket and intake/exhaust gaskets, but you get the idea.
    This head had 180,000+ miles of daily driving. It was formerly in a homemade turbocharged E34... the kid I bought it from said he never head detonation since he was running 7 or 8 psi on a T3, and now I 100% believe him!
    Mar 2004
    That looks really nice - you getting ready to put more boost into that bad boy?
    Scott
    07 525i 22K, 07 328xi (41K)
    PA
    Quote Originally Posted by Scott C
    Scott
    Getting there
    Wow, thats clean. Makes it easy to sea the hairline crack between the exhaust valve seats.
    Bahhhhhhhhhh , seriously you do need to see someone about this affliction. Soda blasting did a great job, I've never seen the results before and I'm thinking about having a very old set of rims done, maybe I'll go for it now.
    Great work as always,
    Dave
    PA
    Dave
    Haha ass, I was like uhhh what crack... i inspected it earlier....
    Thanks!
    Soda blasting will probably do VERY little on rims. It's good for cleaning oil/varnish/sludge, but not paint or powdercoat. Bead blast that - but use chemical strip first!
    baton rouge, loserana
    cool, got my short block built today so ill probably be building my head next weekend, unless i get motivated wednesday or thursday night but that's unlikely, i am happy with how my short block came together, everything plastigauged on the tight end of the specs despite the fact that the crank, rods and block all came from different models, and i balanced the pistons and rods to within a 1/10th of a gram of one another, about 2.5 gr between the heavy and light pistons and 4-5 gr between the rods, i read somewhere that a 7 gr imbalance at something like 6 grand turns into like 28 pounds, that'll suck some power
    Sep 2005
    NJ
    meh, won't compare to the e30 head that is getting redone from Karl's e30
    PA
    Btw winfred - how the hell do you remove the valve seals? I tugged on them with pliers but felt like I was breaking something. Also. do you think putting the valves in a drill and hitting a scotch pad to them is a good idea? I tried soda blasting the exhaust valves and made decent progress it just took a while - gonna soak them in some carb cleaner and try it again next weekend I think.
    Andrew - bwahaha this is only the beginning for this head
    i clean all of my valves on a wire wheel mounted to a bench grinder this gets most of the ****, the most stubborn stuff on the combustion chamber face of the valve sometimes needs more convincing, i usually use the sanding disc on the other side of my grinder but i don't recommend it as if you don't have the right touch you can get into big trouble fast, the way i do it the valve gets pollished, a fine rollock disc on a buffer would be fairly safe and effective
    they make a special pair of pliers for pulling those seals, i don't own them despite the large quantity of heads i build because they are so ****ing expensive, i use a pair of end nippers grip it and rock/twist it off with one handle in each hand, i also have removed them with a baby pair of channel locks called cobra pliers, either way ya go they suck to get off and take it easy on the guides, i've never ****ed one up as they are somewhat tough but.....
  1. Cylinder head repair
    By infurno in forum 5 Series BMW
    Last Post: 11-24-2008, 07:04 PM
  2. m50 cylinder head tools
    By Mendozart in forum 5 Series BMW
    Last Post: 10-27-2008, 12:05 PM
  3. pb was cylinder head WTB M50 non vanos head.
    By Bruno in forum 5 Series BMW
    Last Post: 08-19-2008, 03:23 PM
  4. New Cylinder Head
    Last Post: 04-14-2008, 11:21 AM
  5. m20 cylinder head
    By Fraz06 in forum 5 Series BMW
    Last Post: 06-03-2007, 08:20 PM
