Results 1 to 9 of 9
Thread: Stupid engine problem solved...
    Dec 2006
    UK
    Default Stupid engine problem solved...
    The 540 started running rough when stuck in traffic. You could feel the engine shaking and it felt like it was missing on a couple of cylinders or there was some fueling problem. I had a look a couple of days back and couln't find anything wrong, plugs all looked good and there wasn't any obvious which might be the cause. Had the hood up and gave the engine bay a quick clean and then found the cause...... a missing blade on the radiator fan. I didn't think think this was the rough running/ engine shake problem at first, I just thought ' oh great, something else to fix. Removed said part and problem cured.
    Now to find a replacement fan.
    Cheers
    This is spooky... fan blades breaking apart? Sounds like all of us need to change the blade before catastrophe... seems to be age related rather than mileage. I think this is the third case I heard on this forum.
    Nov 2006
    Germany
    Quote Originally Posted by Tiger
    Could this be a problem while driving long distances at 100mph?
    I guess I should roll the car out into the sunshine and give the fan a stout looking after...
    Brian
    Default Under hood plastic bits
    All of the plastics parts, at least the ones that had ANYTHING to do with the cooling system, under the hood of my '95 began crumbling to bits. I paid a small fortune to get everything replaced last summer, I still wonder if I should have traded it in on 3.5 Liter Altima!
    Nov 2006
    Germany
    Quote Originally Posted by Rusty
    It is these kinds age-related failures that make me want to sell my beast for something ten years younger. Add in some lust for a V-8 and you have a recepie for some car shopping!
    Brian
    Speed has no bearing as the fan clutch will not allow engine fan to speed up beyond certain RPM... so it is definitley age related.
    Derbyshire, UK
    Unless the clutch is seized, which will allow it to spin up the fan to redline.
    1997 535i V8
    Dec 2006
    UK
    The plastic fan shroud had started to crumble at the edges,fan isn't too bad.
    If that happens, you really can hear it... sounds like a turbine engine.
  1. Solved my E34 surging problem...
    By onZedge in forum 5 Series BMW
    Last Post: 09-01-2007, 10:44 PM
  2. Occasional 525i M50 Engine Misfire Problem – Solved
    By stilljester in forum 5 Series BMW
    Last Post: 01-20-2007, 11:11 PM
  3. Problem Solved!
    By cableface in forum 5 Series BMW
    Last Post: 06-18-2006, 08:35 AM
  4. Problem Solved Finally!!!???
    By e34it in forum 5 Series BMW
    Last Post: 05-10-2005, 06:48 PM
