Results 1 to 7 of 7
Thread: t6rany program error
    BMWJEREMY Guest
    Default t6rany program error
    I HAVE A 88 735I JUST HAD TRANY REBUILT AND NEW COMPUTER INSTALLED IN IT. RAN GREAT FOR 3 WEEKS THEN ONE DAY I GOT IN AND STARTED TO DRIVE THE CAR WAS IN LIMP MODE I TURNED THE CAR OFF AND WAITED A FEW MIN. AND TRYED IT AGAIN. BUT STILL IN LIMP MODE. WHEN THE KEY IS IN THE #1 POSITION IT SHOWS THE CAR IS IN SPORT MODE WHEN I HIT THE SELECTORE SWITCH IT TURNS TO ECONOMY BUT WHEN I LET THE SWITCH GO IT GOES BACK TO SPORT MODE.THEN WHEN I START THE CAR UP IT GOES IN TO LIMP MODE AND NO DRIVE STYLE IS ON. WENT TO THE TRANY GUY HE TRYED PUTTING THE COMPUTER SCANNER ON IT AND IT DONT SEEE THE TRANY BUT IT DOES SEE THE ENGIEN. SO HE REPLACED THE TRANY BRAIN AND SCANED IT THEN AND IT SHOWED THE TRANY WAS GOOD TO GO. AND IT DROVE FINE FOR A WHILE BUT THEN WHEN I GOT THERE AND TRYED TO DRIVE IT IT WENT RIGHT BACK TO THE LIMP MODE. ANY ONE HAVE ANY IDEAS HERE I AM STOMPED HERE. WENT THOUGH MADE SURE THE CONNECTOR WAS GOOD AND THE CONNECTION TO TRANY COMPUTER WAS GOOD. PLEASE EMAIL ME IF YOU HAVE ANY IDEAS FOR ME. THANKS JEREMY
    SCHOEBO@HOTMAIL.COM
    do you see the S-M-E and the gear indicator in the dashboard?
    If not, clean the gear selector switch and all is o.k.
    Info how to do is on Gale's page
    http://www.nmia.com/~dgnrg/page_13.htm
    BMWJEREMY Guest
    Default I Do But
    When I Turn The Key In The #1 Position It Comes On In Sport Mode Then When I Start The Car The S-e-m Go Off And It Is In Limp Mode. But When The Ignition Is On I Put It In E Or M Mode It Goes Right Back To The S Mode. Ill Try Cleanning It And See What Happens Any Other Posibilitys? Is That A Reason Why The Computer Scanner Doesnt See The Trany Computer Too?
    I had it once that it did not go into S when switching to S.
    The switch was dirty. I just switched about 30 times through S-M-E while engine was off, and it was o.k.
    But while you clean the gear switch, clean that S-M-E switch too.
    BMWJEREMY Guest
    i did all that but the problkem is still there i even replaced the mode switch to make sure any ideas what i could look at next? please help im so lost and confused and going nuts
    Default If you live in USA contact Kirt Koeller
    He is expert on trannies and helps out a lot on roadfly:
    Kirt Koeller’s contact info:
    Autosports Unlimited
    Ask for Kirt Koeller
    (800)624-3876 ext 5735 or direct at
    (616)748-5735
    europetransman@hotmail.com
    Let us know the outcome of the troubleshooting.
    Good Luck
    Waj wsyed@carolina.rr.com Guest
    Default Tranny error.
    There are two things you need to check. Get some contact cleaner and clean the shift lever switch and also the little auto/manual* mode switch. This sounds like an electrical problem.
    Quote Originally Posted by BMWJEREMY
    SCHOEBO@HOTMAIL.COM
  1. TRANS PROGRAM error: detailed TCU analysis
    Last Post: 09-11-2015, 03:25 AM
  2. A/M switch position trans program error
    By KurtM in forum 5 Series BMW
    Last Post: 07-17-2007, 07:45 AM
  3. Trans error program?
    Last Post: 12-09-2006, 01:20 AM
  4. 540 Trans Program error
    By Katana6434 in forum 5 Series BMW
    Last Post: 03-15-2005, 08:47 AM
  5. Trans Program Error - Rebuilt Transmission
    By T. Martin in forum 5 Series BMW
    Last Post: 06-30-2004, 02:01 AM
