Originally Posted by
///Sniper535
Only when I'm stopped or slow moving.
Bad fan clutch?
My fan shroud has 1 and a half blades missing, this happened when i had my little accident. this never affected the temp, so i don't think it's that all a sudden. I had plenty of coolant, in case anyone asks, no noticeable leaks. I usually check my coolant level every week.
FWIW I've had that symptom from two different causes:
1) bad fan clutch - new one cured it
2) old fluid - flush and fill cured it
Overheating at slow/stop is often a sign that the clutch is bad, as the clutch is what makes the air flow higher when stopped. Try the cheapest thing first - new coolant isn't too bad and a good idea for the start of summer anyway. If that's not it, a fan clutch is a little more but pretty easy to swap.
HTH
- Robin
Robin
72 Chevy K10
01 E39 M5
