Results 1 to 5 of 5
Thread: question for the M20 gurus
    NEPA
    Default question for the M20 gurus
    my friends 89 525i is having a idle issue where it idles like ****. his mechanic said it was the idle control valve. im pretty familiar with the M20 as I have had a 90 325i.
    he ordered one from bavarian auto recycling and they sent the wrong one, the one they sent was for an M50.
    either way whenevber i pulled the ICV connector off the idle would get worse and whenever i plugged it back in the idle got better. is this normal or is the car supposed to stall?
    i told him to send it back and have them send him the correct one since he already paid for it. but upon further inspection the breather hose has a nice crack in it as do the hoses that connect the ICV. are there any other places to check? my theory is that the ICV is still good and there is a vaccum leak somewhere that has to be discovered. the M20 sure looks small in the E34's engine bay. or im just used to seeing an M60 in mine.
    Mark
    1999 M3 Cosmos Black/ Black 78k
    1994 540i Oxford Green/ Silver Grey Sold @ 133k
    1995 M3 Arctic Silver/Black Sold @ 117k
    1990 325i Zinnobar Red/Black Sold @ 115k
    baton rouge, loserana
    clean the icv with carb cleaner, if you flick your wrist the right way you can snap the valve open and closed quickly to verify it's smooth operation (and hepl in cleaning if you squirt a bunch of cleaner in there), now make sure the tps is clicking and making contact to go with that click (it only clicks for closed), the tps has 3 wires, the center is common one outer is full throttle and the other is closed, you are looking for continuity
    There is also an awful engine harness barrel connector under the intake that will corrode and fall apart, causing all sorts of whacky problems, down to inop and non-starting symptoms. I'm not actually sure if that unfortunate design made it onto E34 M20 cars, but it is a pain in the butt on E30s.
    Vacuum leaks, intake problems....all par for the course.
    Honolulu
    Default It's there
    Quote Originally Posted by Kalevera
    Runs the injectors etc.
    New Mexico
    Quote Originally Posted by markus
    Markus, l am having similar issue, my M20 is idling to fast (1200 to1450rpm). I have taken every hose and clamp off along with the Idle Control Value, throttle body & Air Flow Sensor and used carb cleaner. Put everything back and no change. Checked the air flow sensor per the Bentley manual, 5 volts on terminal 3. I connected ohmmeter across terminals 2 & 3, moving the flap throughout its range, the resistance changed steadily. So I assume all is well with the Air Flow Sensor.
    Now to test the Idle Control Value, according to Bentley "If the valve is not buzzing with the engine running, or if the idle decreases when the A/C is turned on or shift the car into drive, then you are to disconnect the harness connector and check for resistance on the valve across the terminals. (1 and 2 = 20 ohms give or take 2 ohms, same for 2 and 3, 1 and 3 = 40 ohms give or take 4 ohms) 1 and 2, 2 and 3 checked out okay, but at terminals 1 and 3 I only had 29-31 ohms instead of 40 ohms??
    I performed the stomp test and I got Code 1215 Air flow/air mass sensor. The code 1215 would just repeat over and over again. Tried to clear codes but no luck....
    What next? I guess I will try ICV tomorrow, is that what YOU would do. Any help would be greatly appreciated.
    Installed new ICV, the idle is fixed.......
    M20 525/7 Bore: 84.50mm Stroke 81mm CR 8.5:1, blue printed/dyno & custom chip. Boost @ 6.5psi ~246hp @ 5300rpm / torque @ 269ftlbs. @ 4250rpm
  1. LKM Gurus, Help Please......
    Last Post: 04-19-2006, 03:22 PM
  2. Suspension Question for Touring Gurus
    By KennyG in forum 5 Series BMW
    Last Post: 01-19-2006, 07:06 AM
  3. Question for steering gurus....need some help
    By mikemaster in forum 5 Series BMW
    Last Post: 11-25-2004, 12:47 PM
  4. Question for the "switch" gurus.
    By Keith in forum 5 Series BMW
    Last Post: 10-12-2004, 08:27 PM
  5. OT: GM 4T60E auto box problem - help question for the transmission gurus
    By Anthony (M5 in Calgary) in forum 5 Series BMW
    Last Post: 04-26-2004, 01:18 PM
