Results 1 to 10 of 13
Thread: stock diff ratio for 540iA?
    NEPA
    Default stock diff ratio for 540iA?
    is it a 3.15? also will a 530i driveshaft bolt up to my 540i's stock diff or no?
    Mark
    1999 M3 Cosmos Black/ Black 78k
    1994 540i Oxford Green/ Silver Grey Sold @ 133k
    1995 M3 Arctic Silver/Black Sold @ 117k
    1990 325i Zinnobar Red/Black Sold @ 115k
    Tampa Bay, Florida, USA
    2.95, I think.
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    2:98 I believe. the 3:15 is a half ass attempt of an upgrade. I dont know final ratios in the trand but my 530 with a 3:64 does 3000 rpm at 87MPH which is more than acceptable. I previously said 3K rpm at 83 but I was smokin crack at the time. I wouldnt upgrade just to the 3:15 mattering on rpms in final drive, seems a bit of a waste of time and money.
    East Brunswick, New Jersey
    2.93, see picture.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    E34 530 uses a medium case differential, 540 uses a large case. The input shaft is different, as are the half shafts and wheel bearings. So out of the box, the 540 diff won't plug and play in a 530. HOWEVER, you can buy a CV that will fit onto the 530's shaft and work on the large case diff. So you just have to replace the half shafts and bearings or swap trailing arms with a 540/740/750 to make it work.
    NEPA
    im confused. all i wanted to know is if i do the 5-speed swap will the 530i 5-speed driveshaft bolt onto my stock 540's diff. im NOT looking foreward to swapping differentials if that is the case.
    Mark
    Apr 2004
    Reston Va
    After I did the 6 Speed conversion on my 540 - the 2.93 diff was pretty anemic when I was tracking it. I changed out to the 3.15 LSD from Koala Motorsports. They are the guys that did the 6 speed conversion in the first place. I talked to Brett there and he suggested the 3.15 ratio - and now on the track the car pulls through the corners beautifully.
    I think it was a great upgrade to go with the 6 speed conversion. Nothing half-assed about it. - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    Jul 2007
    Long Island, NY
    Quote Originally Posted by Johntee540
    What RPM are you doing in 6th, at about 75mph?
    -AJ
    -Two E30s, an E34 and an E46-
    May 2006
    NH
    What happened to your WOT sixth gear power drive speeds?
    1995 540i Manual build 1/95
    Feb 2007
    How much is a 6 speed conversion? Any recommended places in the south of the UK to carry this out? is it just box, clutch, gearshift, pedal or is there more to it such as new ecu and loom etc? I am seriously toying with this idea at the moment because I think my torque converter is on the way out...
  1. Replies: 3
    Last Post: 10-01-2008, 08:31 AM
  2. What ratio is my diff?
    By RiggsyB in forum 5 Series BMW
    Last Post: 08-07-2006, 05:47 PM
  3. Help figure out what diff ratio I have
    By permit in forum 5 Series BMW
    Last Post: 02-06-2006, 08:01 PM
  4. Changing diff ratio questions
    Last Post: 08-13-2005, 11:51 AM
  5. Replies: 1
    Last Post: 10-08-2004, 11:52 PM
