Results 1 to 10 of 20
Thread: Hood Struts?
    May 2006
    NH
    Default Hood Struts?
    Any better deal for Hood Struts
    1995 540i Manual build 1/95
    Chicago
    Looks like normal price to me
    _
    Sep 2006
    San Jose, CA
    Default autohausaz
    http://www.autohausaz.com/search/pro...rut,%20%20Hood
    Not cheaper, but if you buy other stuff upto $50, there is no shipping charge. grap some oil filters, microfilter... or something
    Quote Originally Posted by Jehu
    94' AlpineWhite 530i, 5 spd Auto, 112K miles, Mfg in 4/93
    May 2006
    NH
    Should i get retaining clips too or can i get them off without mutialting them?
    Dec 2006
    North Tonawanda, NY
    How old are the original clips? I would pay the 2 bucks and get the new ones.
    Pretty much $30 all day long.
    six forward speeds
    pa
    It's pretty easy to take out and put in, about 2 min each side if you know what you're doing. Just go out and try to remove one before you order.
    The retaining clips come with the new strut, see pic on Autohaus. No need to order.
    And then you still have the ones from the old ones as spare.
    I order the struts from Meyle and they are also with clips attached.
    Never have seen a new strut without a new clip, at least not the usually known brands.
    Minnesota
    Default $14.52 each at rockauto.com, not sure on shipping.
    but they have a lot of choice for other items like brake pads and plugs.
    Jeff in MN
    87 535is 245k Recent top end re-work
    88 528e 290k
    90 535i 115k
    98 740i 115k New Magnaflow Cats, No More Codes
    $ 14,52 each at rockauto does not beat Autohaus Arizona's $13.53
    But you are right, it is worthwhile to compare with rockauto, some items they have really cheap, for example they have a lot of reman items like brake booster units etc.
    But my main U.S. supplier is Autohaus Arizona, very satisfied with prices and service.
    The rest I buy from my sources in Germany cheaper, such as Meyle parts, Hella regulators, etc.
    May 2006
    NH
    While you're here I thought i'd ask about my flakey locking system. I know there are DIY write ups but i wanted to ask that If the symptom is the front passenger lock kicks back when using the remote or locking from trunk but locks when i lock from that front passenger lock manually do i need to replace the actuator or will some graphite in the mechanism do it? It seems to operate on very warm days fine so i know it can work it seems when its cooler the lock sticks and i need to lock manually.
  1. Hood Release - only partially opens hood
    By Al Gray in forum 7 Series BMW
    Last Post: 11-30-2009, 10:32 PM
  2. Replies: 10
    Last Post: 01-20-2006, 01:58 PM
  3. Water between hood and hood liner
    Last Post: 05-08-2005, 10:33 PM
  4. Who has these Hood Struts?
    By lino in forum 5 Series BMW
    Last Post: 03-10-2005, 01:09 AM
