All written on Gale's website.
If you don't know where to find, click my website below, there is a link to Gale.
All the same for E34 and E32.
i still havent gotten my car back yet but since the warranty company will be giving the mechanic some money i was wondering how much typically would the parts run me for a 5-speed swap? also does it just bolt right in? from what i have read the 5 and 6 speed gearboxes have identical ratios from 1-5 and 6th being overdrive.
there isnt really a manual swap writeup for the E34 anywhere.
Mark
1999 M3 Cosmos Black/ Black 78k
1994 540i Oxford Green/ Silver Grey Sold @ 133k
1995 M3 Arctic Silver/Black Sold @ 117k
1990 325i Zinnobar Red/Black Sold @ 115k
http://forums.bimmerforums.com/forum...d.php?t=729157Originally Posted by markus
Almost everything you need to know - and then some - in that thread.
Costs-wise, well - that's really up to you. I've got a sub 90k Getrag 250 5-speed, with the linkage, shifter, seals, and crossmember that I'll send your way for $275, or you can drop the major coinage on the 6 speed. You can get a driveshaft off of eBay (check 'Strictly German'), and you'll need a pedal cluster, as well as dozens of other little odds and ends (bolts, springs, washers, clutch hose, fluid lines, clips, plugs, grommets, etc) from the dealer. You'll also need a flywheel, pressure plate and clutch and the stock dual-mass flywheel is expensive when new. You can get a used one from a boneyard. You'll also want to change out the rear-end since you probably have a high-ratio back there for the automatic.
In short - you can expect to shell out probably close to $2k for the transmission and the associated bits and pieces to do it correctly with BMW parts. Less if you cut some corners and/or get lucky.
Car Info is HERE
