Results 1 to 1 of 1
Thread: New Wrinkle in the Blower Issue
    May 2006
    NH
    Default New Wrinkle in the Blower Issue
    I today positively identified a lose connection in the Main Fuse Box causing my Blower Intermittentcy. It had gone off as i drove over a hump in the road as i drove straight in to rush hour gridlock. I got off the next exit and went to Gas up and check the fuse. As i had the key in and the blower switched on i opened the Fuse Box and checked #19 which was good so i replaced it. Then i just started gently moving the relays and modules in that box and i think it was a yellow one i touched and the blower went on so i went in and started the car then it went off again . Out back to the Fuse Box and repeated the gentle jiggling of the parts enclosed therein and it was back on. I didn't get to pinpoint the culprit because i didn't hear when it came on but later it went off again and this time a simple tap to the whole box while closed got it to come on so should i unbolt the Fuse box and check the harness leading to and from the base? Any known fixes? Do these Blower Motors REALLY go bad all that often? I bought one from a junk yard with 80,000 miles but if my problem is just lose connections i wonder if i should get my $60.00 back or hold on to it .
    1995 540i Manual build 1/95
  1. What you guys think - wrinkle black cool?
    Last Post: 10-09-2007, 09:34 AM
  2. A/C Blower issue?
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 06-09-2007, 12:58 AM
  3. Blower
    Last Post: 11-18-2005, 12:50 AM
