Need to drain Coolant to R & R Heater Blower?
I have the expansion tank in front of the blower access and the Bently says to remove the hose from the tank . Is this presupposing you've drained the coolant or can you maybe clamp the hose, suction out the tank then remove it ? Only reason i ask is if i don't need to drain all the coolant i don't need to have the shop do it. Something tells me though the hose is really too big and stiff to clamp enough to avoid the gushing I'd want to avoid.
1995 540i Manual build 1/95
