Originally Posted by
BimmerMeUp
1992 Touring
SLS Delete
M-Tech Springs F/R
Bilstein HD's
Staggered Style 32's (235/45/17F 255/4017R )
Alignment done with a full and of gas and weights added.
Front
Camber Left 0.1
Camber Right -0.4
Caster Left 7.9
Caster Right 7.5
Cross Camber .5 (on limit of spec -0.5 to 0.5)
Toe Left + 0.14
Toe Right + 0.19
Total Toe + 0.33
Rear
Camber Left - -1.3 (out of spec -2.8 to -1.8)
Camber Right - 1.7 (slightly out of spec -2.8 to -1.8)
Cross Camber .4
Toe Left 0.10
Toe Right 0.14
Total Toe 0.24 (out of spec 0.30 to 0.53)
Thrust Angle -.02
I've done of bunch of work on the front (Lemforder Thrust arms and Control Arms with 750i bushes on the thrust arms, replace a bad tie rod end, replace idler arm bushing, replaced strut bushes.) The rear only has the parts needed for the SLS delete changed. I meant to replace the dogbones before I took it in, but I forgot to order them in time.
The techs were drooling over the rims, could have sold them at a healthy profit. They definitely look better in person than in photos. I haven't come up with a good one to post.
