Results 1 to 10 of 20
Thread: Homemade Spring Compressor
    Seattle, Wa
    Default Homemade Spring Compressor
    Any site(s) with instructions and material list for making a spring compressor for the E34?
    TIA
    Honolulu
    Default Which Spring?
    valve, suspension or piston return
    PA
    suspension most likely
    Although we built a double valve spring compressor recently lol
    Easy. You'll need:
    1) Tennis court
    2) Wall or other solid object ~2.5-3' from the court. I've used planter boxes and sides of condos.
    3) A quiet day when nobody is playing tennis
    Now, squeeze the strut/shock assembly in between the solid object and the tennis court fence, ensuring the top bolt is easily accesible from INSIDE the court. Next, get inside the court (remember to wear not-marking, non-slip, comfortable shoes) and turn the top nut off, just as you would with a professional tool. Next, observe how much you flinch and how far the fence actually caves when the bolt finally busts loose.
    OR, you can rent a real one for ~$10.
    I don't condone use of the first 'tool' described
    Dave
    East Brunswick, New Jersey
    Quote Originally Posted by JMI
    TIA
    Why the trouble? Go to Autozone and borrow them for free.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    Honolulu
    Default bought a cheap one
    off of Ebay for less than $20.00, when I dropped in the Eibachs.
    TIA
    I used a tow strap once, for the rears. Just cranked it down by hand, one side at a time. Wrapped it over the top and bottom coils. Didn't lose any fingers so I count it as a success... though I like Dave's method better.
    Robin
    72 Chevy K10
    01 E39 M5
    Maryland
    i don't recall a site with directions but google will find it for you in .0314 seconds
    i'd use a few pieces of all thread, some nuts, some steel hooks, and an acetylene torch
    It is dangerous when it breaks or slips (the selfmade one). That spring can injure you.
    Buy one for your car or rent one.
    Jun 2006
    Sydney Oz
    That spring can kill you - not just injure you.
    I paid $28 for one.
    '90 E34 M5
    '89 E34 535i
    '74 R90S
    MB 560SEC
    '74 Jensen Interceptor
    '54++ VW Subaru Turbo hybrid
    etc
  1. Spring compressor question
    By Dave M in forum 5 Series BMW
    Last Post: 11-18-2009, 06:44 PM
  2. OT: Spring Compressor
    By Traian in forum 5 Series BMW
    Last Post: 10-11-2006, 10:08 PM
  3. Strut change spring compressor?
    Last Post: 04-09-2006, 03:20 PM
  4. where to rent a Spring Compressor?
    By ronn227 in forum 5 Series BMW
    Last Post: 04-08-2005, 02:57 PM
