The crankcase ventilation line on the lower left side of the intake elbow is the entry point. A bit of oil there is normal, as the oil vapour sucked out of the engine condenses in the intake. If you've got (or had) a vacuum leak, it may be a bit worse, as the oil vapour is more likely to condense than get sucked into the engine where it belongs.
