soft thrust arm bushings/control arm bushings, bad dogbones in the rear, rear subframe bushings, uneven tire pressure, funky tire.
Slight but noticeable "pull" to the right when appling the brakes with semi-firm pressure.
Wheel alighment just done so not the culprit.
1. Could be one or more pistons in the LHF caliper stuck in the bores = greater braking effort from right caliper = pull to right.
2. Collapsed RH thrust arm bush or ball joint = wheel moves slightly to the rear under brakes = pull to right
3. LH Rear suspension 'dog bone' (pitman arm) sloppy so LH rear wheel moves slightly toe out under brakes = rear steers to left = apparent pull to right
June 88 535iA, 173,000 km; Sep 00 735i 170,000 km
Mines pulling to one side at the moment, but it's cos I've got a busted shock...
