Diagnosing wheel bearing
I'm about to take the car into the barn and check things out. It started as a slight metalic squeeling, then like a scraping kinda like a brake pad wear sound then worse. At first I thought it was brake pads cause it went away if I would hit the brake then it didnt. Sounds like garbage is rubbing metal to metal, no whirring or humming though. How can I tell if its a bearing or is it obvious? How to test if not?
Jeff
