i've taken several of them apart and gotten them going again, not that hard
I've done this actually last week. They are pretty easy. Did it chuck a CD ERROR also?Originally Posted by BigKriss
pull the CD stacker out mate, and take the covers off, you'll have to do it manually you should be able to pull the cd up using a cog at the front middle which controls a screw with moves the cd's up and down on the player side (as opposed to the magazine side) then once it is aligned with its original position on the magazine see if you can manipulate the cogs at the back so that it spits the cd back into the magazine.Originally Posted by BigKriss
once you get the cover's out (including the bit which has the eject button on it) you can remove the mag by pushing down on the bit just below the front of the magazine.
