Results 1 to 10 of 12
Thread: Regluing the passenger window
    Jan 2007
    Dayton Ohio
    Default Regluing the passenger window
    Looks like the passenger window glass has separated from the track. Looks like they used some kind of epoxy to attach it. Where do I get this stuff?
    butyl will work fine.
    Jan 2007
    Dayton Ohio
    What the heck is Butyl. I have heard of butyl orings and things like that but is it available in a glue form? man never heard of that before
    Jan 2007
    Dayton Ohio
    Local mechanics told me to use windo weld super fast urethane 080609 for window repair. They said when I use this stuff make sure everything is aligned correctly I only get one chance/.....
    Urethane glue should work okay too, make sure to clean the window and glide and then set it within the existant marks and let set 24 hours or whatever it says on the glue.
    Jan 2007
    Dayton Ohio
    Thanks for the info. Hope I can find the existing marks
    Man that is one scarry picture.
    once you get it cleaned up good you should see something, all else fails fill the seat with glue and carefully roll it up all the way. should self center for you pretty close.
    Jan 2007
    Dayton Ohio
    I am assuming there is an adjustment once the window is glued and set?
    i doubt there might be much forward rearward action since the window comes with the bracket attached before it is installed...look for them marks, has to be some dirt around where it used to sit.
  1. Passenger side window rolls the seal
    Last Post: 07-25-2007, 12:01 PM
  2. BMW E34 - 530i - Passenger Window
    By REtzler in forum 5 Series BMW
    Last Post: 03-19-2007, 05:15 PM
  3. Passenger window off track
    By GregW in forum 5 Series BMW
    Last Post: 12-18-2006, 02:01 AM
  4. passenger side window slipping
    By bimmer95 in forum 5 Series BMW
    Last Post: 08-28-2006, 03:35 PM
  5. rear passenger door window shattered
    By bbig119 in forum 5 Series BMW
    Last Post: 07-05-2006, 07:30 AM
