Results 1 to 5 of 5
Thread: copper ring that holds headlight bulb in
    Long Island, NY
    Default copper ring that holds headlight bulb in
    I had to replace a bulb and opted to do the upgrade to 9005 so I replaced both bulbs today after the quick and easy modification. When I went to remove the old bulbs, the copper ring that helps hold the bulbs in on the light fixture came out. I replaced it when the new bulbs went in but the rings aren't tight against the fixture and consequently, the bulbs are also not held in as tight as I thought it should.
    Looking at RealOEM, I can't see this copper ring or a part number for it.
    Any comments or suggestions?
    Bryan
    '94 540I 6spd/205000 miles
    Long Island, NY
    Come on....I know somebody can help me a little here. At least tell me of I should be getting a snug fit with the 9005 bulbs in the lowbeam socket.
    El Paso TX
    Quote Originally Posted by bbig119
    no.
    Not unless you removed the larger sealing ring from the 9006 and added it to the 9005 in addition to the normal 9005 bulb ring.
    Long Island, NY
    Quote Originally Posted by attack eagle
    no.
    Did that. So I have both the old o-ring from the 9006 and the new smaller o-ring that was on the new 9005.
    Qube, I'll try to get a picture ASAP, been a bit hectic lately.
    Thanks for replies.
    T·O·R·O·N·T·O
    A picture would help. I've been removed from OEM lights for too long to remember.
  1. ::.. Depo Halo / Angel Eye Projector Ring Bulb
    By Qube in forum 5 Series BMW
    Last Post: 08-28-2006, 02:32 AM
  2. Replies: 0
    Last Post: 06-27-2006, 01:00 PM
  3. Headlight out but not LKM or bulb
    By ra_pro in forum 5 Series BMW
    Last Post: 11-22-2005, 04:36 PM
  4. How to replace bulb in the headlight switch?
    By Mario in forum 5 Series BMW
    Last Post: 08-28-2004, 10:26 AM
  5. Replies: 7
    Last Post: 03-10-2004, 09:30 PM
