Try checking these things:
- distributor cap for corrosion + rotor
- plug wires; old or varies in resistance
- all the vacuum lines, in particular the 3mm lines under the intake manifold
- the hose that runs from the ICV to the intake manifold - cracks + tight hose clamp.
- intake boots after the AFM for cracks, tight hose clamps, tight connections with the fittings
- wipe off the back of your throttle plate with carb clean (never have figured out why this helps)
- Check the vacuum line from the intake manifold to the brake booster - the hose, the check valve (can crack and leak) and the fitting into the booster.
- Check the blue engine temp sensor connection for corrosion, clean if needed
- Check your injector seals, replace if needed
- While at it, stuff in some newer Ford Bosch 19 lb injectors
- Adjust your idle mixture on the base of your AFM
Yup. One of those for sure. That pretty much ought to cover it. Have fun.
Bellevue WA
86 Porsche 951 - Track Toy
