just got my pully today, Im not going to measure how tight but as a guess id say 35~40 ft lb
Guys can't find this anywhere in the Benteley. What do you torque those pulleys that are attached to tensioner down to?
Yeah I know you don't need a torque wrench for this type of job but I like to do everything by the book.
FS: PBR Deluxe rear brake pads [new]
You going to replace the tensioners as well Jeff?
just the worn pully, sounds real bad today when I ran to the post office, wondered if I would make it back. I will inspect more stuff when I get in there tomorrow cause I am going to freshen the AC belt too.Originally Posted by Anton CH.
Look at the bolt size. IFRC it is 8 mm. And then look at the grade on the bolt head. Most likely it is grade 8.8. Then use the torque seting table.Originally Posted by Anton CH.
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
uh-ohh the smaller idler is wasted! Looks like its E31 weather for a few days...hmm the AC idler is the same thing, the ol switcheroo is what Im going to do.
where'd you get your pulleys? Are there aluminum ones available or just plastic? I'm replacing my Rad, maybe its a good idea to replace these as well?
They are plastic. Take off the belts and spin them. If they catch or make noise--replace.Originally Posted by Boone.Msi
Sorry to stray off-topic, but i believe the idler pulley is catching, the pulley on the bottom right passenger side will spin then stop suddenly, followed by a change in engine speed(sound like a catching idler pulley to you?)
The bearings are in the pulley itself correct?
Another question i have is which one to get? I believe they are standard 80mm but on BMA they have a 70mm option? take a look:
http://bmaparts.com/item.wws?mfr=INA...81731220%2Ejpg
Yes, these pulleys have the bearings built-in.
Which one are you looking for?
The idler is 70mm, deflection pulley 80mm.
