Results 1 to 5 of 5
Thread: For the manual trans that calls for ATF-which ATF?
    Bergen County - New Jersey
    Default For the manual trans that calls for ATF-which ATF?
    hey guys.
    just doing a tune up on the 535 and was wondering what the concensus was on the ATF. I'll probably just use the standard mercon 3 but what do you guys say?
    also, does anyone have the spec on how many foot pounds for the spark plugs and the valve cover bolts?
    thanks a lot
    pablo
    Kingston, Ontario, Canada
    For ATF you can try either Redline D4-ATF or Mobil 1 Synth ATF. I'm running Mobil 1 Synth after a winter of Redline MTL. Mobil 1 is noticeably smoother in all temps.
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    NY
    I switched to Mobil 1 ATF a month ago, just because I was under there anyways doing the oil, and there was absolutely no difference at all. So, I would say go for it, but don't expect anything out of the ordinary. I may try Redline later on and see how that works, but the tranny shifts fine as it is so I'm not trying to eleviate any problem.
    Custom Turbocharged 1991 535iM - 135k mi.
    Near San Francisco, CA, USA
    Default I use RedLine MTL in my 535 and it is GREAT....
    Better than the ATF my indy put in.
    Quote Originally Posted by Uncle Paully
    hey guys.
    thanks a lot
    pablo
    Mobil 1 ATF is very good stuff in manual trannies spec'ed for ATF.
    George
  1. Switching Auto trans to Manual trans
    By oleh in forum 5 Series BMW
    Last Post: 03-21-2006, 04:39 PM
  2. 530 + manual trans going in 40 minutes 107 bux
    Last Post: 10-04-2005, 08:26 PM
  3. trans swap - manual
    By stx133 in forum 5 Series BMW
    Last Post: 09-05-2005, 09:36 PM
  4. 535i Manual Trans
    By cosworth in forum 5 Series BMW
    Last Post: 01-17-2005, 04:54 AM
