Greetings,
Since the Bently guide doesn't tell you what wrench/socket you need to remove the bolt for the front seat, I thought I would list it hear for others' benefit.
The socket is an E14 (External Torx Bolt size 14).
A website that helps in fixing the twisting seat problem is here:
<http://www.nmia.com/~dgnrg/page_11.htm>
Cheers.
And as the article states, you can use a common 12 point socket to remove them, you do not need a special Torx socket. I wasted quite a bit of time figuring that out the first time i pulled my front seats.Originally Posted by kmraj
