Results 1 to 10 of 13
Thread: plug wires
    Default plug wires
    WOW! spark plug wires over $300 a side in the US!!! conspiracy I think, can I just get a roll of the stuff and rebuild them?
    Honolulu
    Default Is in't two
    m20 sets?
    Chicago
    Call BMA and other places like MSD. I know of other kits out there for the M20, M30 & S38. These other kits are also superior with better shielding. The only thing is it is a little more difficult to bend and snake into place. The pros, better shielding, cheaper price & quality.
    Brandon J
    Aug 2004
    Dubai
    well ... I remember once that the cable is molded with the plugs they are not like those old ones that u screw in the plug. still ... it's not a big deal, u need to get good shielded wires that stands 15KV without leaks, the ones with the thin wire are the best as far as I know. I also remember once I was told that the wires used by BMW are resistive wires, it should read between 3.5K - 6K depending on the length between the distributor and the plug.
    I suggest you get the distributor and plugs and build one, just keep the old one untouched, if it works without any misfiring and u feel the difference then u do the same for the other side ... otherwise u plug in the old wires and find better material for the rebuild.
    good luck
    Bought a seta while back from Bav Auto ~$400 for both sides. I kept the old ones, if you want them to rebuild you can have 'em.
    Aug 2004
    Dubai
    may I know if you gained any power difference after this change? is it more than 10%?
    Just a moment, we are talking here from M20 to M70 engine. The V12 spark plugs are much more expensive.
    http://www.autohausaz.com/search/pro...g%20Wire%20Set
    Here is a possibility to make it cheaper for a V12
    http://bmwe32.masscom.net/sean750/Re...ireSet_V12.htm
    Here they might be cheaper
    http://www.pitstopparts.com/store/br...lug_wires&my=1
    Or if you want to have them made
    http://www.kingsborne.com/
    http://www.kingsborne.com/html/bmw.htm
    I asked him if he noticed a difference today and he said a definite yes, dont know about 10% tho...
    Quote Originally Posted by grave77
    Aug 2004
    Dubai
    that's cool, what made you decide that you need new wires? shimmy engine? or what
  1. spark plug application chart, plug gap, torque
    By shogun in forum 6 Series BMW
    Last Post: 10-15-2009, 12:33 AM
  2. What are these wires for?
    By ArtemLepilov in forum 5 Series BMW
    Last Post: 03-31-2006, 02:56 AM
  3. Euro Smiley's: not plug and play with US plug
    By Elekta in forum 5 Series BMW
    Last Post: 12-17-2005, 03:50 PM
  4. Plug Wires???
    By jiminEcricket in forum 5 Series BMW
    Last Post: 03-18-2005, 04:25 PM
  5. Wires
    By jj7 in forum 5 Series BMW
    Last Post: 12-01-2004, 02:25 PM
