Results 1 to 5 of 5
Thread: Does bigger mean wider?
    Seattle, Wa
    Default Does bigger mean wider?
    The 1989 535i has the stock wheels - 15" and stock size tires 225/60. By my calculations this makes for a total diameter of approximately 25.60".
    If I want to keep the overall diameter the same for the sake of speedometer accuracy then going to a larger wheel size with the same tire width will get me:
    225/55 R16
    or
    225/50 R17
    If I go with a bigger diameter wheel ideally shouldn't I get a wider wheel? Is there an accepted standard for figuring that? About how wide can I go with the 535i without flaring the fenders?
    And finally, is there a web site that will calculate all the possibilities?
    TIA
    Jim
    baton rouge, loserana
    heres one of the best calculator i've found http://www.bncoffroad.com/tire_gear_cal.html
    Seattle, Wa
    Nice
    Hockinson, Washington
    USA
    you want to maintain the contact patch aspect ratio, so you would need to go to wider tires due to the way the tires deform, not much though, think 1" per 1".
  1. Replies: 23
    Last Post: 06-04-2006, 10:21 PM
  2. Wider grille
    By nuwde in forum 5 Series BMW
    Last Post: 08-08-2005, 09:41 PM
  3. Speed channel says wider disks = less HP
    By Gooch in forum 5 Series BMW
    Last Post: 03-31-2004, 11:57 PM
