1) Knock fan loose. Remove fan and clutch. Fan is reverse thread. Use a 32 mm wrench and a big flat blade screw driver if you don't have the bike tool.
2) Loosen s-belt. Remove plastic cap of the tensioner. Insert a 13 mm socket with a ratchet to loosen the belt.
3) Remove water pump pulley, 4 bolts. Use 10 mm socket.
4) Remove thermostat housing, four bolts, one 13 mm socket, the remaining three use 12 mm socket.
5) remove water pump, four nuts, 10 mm socket ( I think).
At lease replace the two o-rings if you do not replace the water pump, t-stat, or t-stat housing. Installation is reverse of removal. tighten the 10 mm socket bolts and nuts to 10 N-m, tighten the 12 mm and 13 mm socket bolts to 20 N-m. See picture.
