Results 1 to 10 of 10
Thread: Help with chip replacement procedure
    pa
    Default Help with chip replacement procedure
    I got stuck at step 5 in this tutorial
    http://bmwe34.net/e34main/upgrade/chip.htm
    I saw that there are 2 gold color mounting clips, but I couldn't pull it hard enough to remove it. It looked kind of lopsided too (one clip is higher than the other side). Do you guys just remove it with your finger? How hard do I have to yank it? Will I damage anything if I just get some wire hanger and yank it out? Thanks...
    USA
    i had to use a crowbar
    pa
    Quote Originally Posted by BillionPa
    Are you being serious? I guess BMW didn't want us to pull those clips out.
    did you get the boards seperated? if not theres your problem, first time it took me quite a while but now it takes like 5 minutes from the time I open the hood. Perserverance helps along with a few beers, no crowbars either. The first time I couldnt get the boards completely apart so I fished the chip off the board with a small screwdriver noting the direction of the original chip (very important)
    pa
    I think I need to remove the whole DME first. I'm stuck at step 5. Thanks
    step 5... use needle nose pliers to remove the gold colored clips (pull straight up), then you need to kinda hold the dme box towards the front to get it to slide out of the slot. I'll keep an eye out on this thread
    Quote Originally Posted by txp135
    pa
    Thank you Regal, I will update...
    pa
    OKay, I finally got all the way to the chip last night. It's fairly easy to do and can be done within 15 minutes. Thank you BillionPA and Regal.
    does it run now? Notice any improvement?
    pa
    I don't have the chip yet, I had to make sure I could open it before Mark sends the chip. By next week I should have it. I will update then. Thanks again... Thu
  1. Lad Shock lower seal replacement procedure images
    Last Post: 04-20-2010, 05:51 PM
  2. Steering lock replacement procedure?
    By bubba966 in forum 5 Series BMW
    Last Post: 07-05-2009, 11:11 AM
  3. Replies: 3
    Last Post: 12-20-2008, 10:58 AM
  4. Thrust Arm Bush Replacement Procedure!
    Last Post: 10-23-2008, 01:46 PM
  5. Rear wheel bearing replacement procedure?
    By Jjcarr in forum 5 Series BMW
    Last Post: 08-01-2006, 10:35 AM
