Results 1 to 10 of 11
Thread: E32 seats into E34 - wiring
    Jun 2006
    UK
    Default E32 seats into E34 - wiring
    Hi I got my seats from an E32 7 series but I'm struggling with the electrics! I have the loom but don't know where to put it. There are two other smaller looms which go forward and to the rear. I have only the 12 pin plug on my 5 series. Can anyone help please?
    If you have the late E32 memory wiring harness, it plugs into the existing driver's seat harness connector and then routes to the seat. If you have the earlier style seats/harness, then it may have to be spliced into place.
    Mar 2007
    WI
    Quote Originally Posted by Kalevera
    Tried putting seats from a 93 740 into my 95 525 and the 12 pin plugs are different. Wires are in different locations and the plug is slightly different so it wouldn't plug in without modification.
    Better check the year of production.
    Also: what do you mean by electric?
    With memory seats? With heated seats, lumbar support?
    Here are all E32 wiring diagrams
    http://shark.armchair.mb.ca/~dave/BMW/e32/
    Jun 2006
    UK
    Its a 1989 750i with electric headrests, memory, lumbar support etc. Am I right in thinking that the 12 pin plug on my 1990 525i is all I need after changing the wires round? What about the other two parts of the loom from the E32?
    Maybe that helps you
    http://www.realoem.com/bmw/partgrp.d...54&hg=61&fg=10
    I took my 11/88 750iL, which is a 1989 model, with memory seat, electr. headrests, lumbar support, heated front and rear seats, single rear seats, electric and also heated.
    Mar 2007
    WI
    well, I found my problem. After searching though schematics I believe that the e32 seats should have two 12 pin plugs. X275 and X626 according to the schematics here --> http://shark.armchair.mb.ca/~dave/BMW/index.html
    When the boneyard removed the e32 seats they unplugged X626 and cut off the harness to X275. I tried plugging in X626 into X275 so obviously that didn't work. I do have enough wire left that if I can source the X275 connector and pins, I should be able to plug in the seat.
    I'm still curious though if the memory for the seat will work without the memory mirrors and steering column inputs or if the software will try to throw a code and prevent it from working.
    Uh, again, until you figure out the exact production date of the donor car and what system the car the seats were sourced from uses, I don't think you'll get an answer. The cutoff date for the early system is 3/93.
    If you have the late system, memory on the seat typically works fine without the column or mirrors in place. Sometimes it gets messed up and has to be reset. Fairly simple.
    The late system's body harness is the exact same as any non-memory car. The memory harness has about 7 connectors for the memory control module and seat, and unless those are plugged in, nothing -- not even seat movement -- will work.
    Mar 2007
    WI
    So which is it? Uh, have you actually done this yourself or are you taking information from another source?
    Not sure on the production date of the car but the module I have is a 61 31 1 388 561 meaning it is an early production. (61 35 8 356 510 is the later module)
    Quote Originally Posted by ///Meisterbrau
    Haha...I'm one of the few enough to do the full conversion, with bits in other cars.
    You know what they say about kicking a gift horse in the mouth. Lucky for you I'm not easily offended.
    61 35 1 388 561 and 61 31 1 378 662 are the early modules. So perhaps the harness has to be spliced (don't know), and the memory may or may not work (also don't know). My knowledge only pertains to the late system, as mentioned.
    I have 3 E32 750 parts cars at the shop, the remnants of another four 750s in crates, and I bought another one today -- an 11/92 with some great and rare options! One of these days I'll get into the early system.
  1. Wiring problem 95 540 sport seats into 90 525
    By mancini_mark in forum 5 Series BMW
    Last Post: 06-26-2009, 10:48 PM
  2. HELP my e32 memory seats dont fit my e34 wiring plugs
    By mystic_525_tds in forum 5 Series BMW
    Last Post: 02-05-2009, 04:09 AM
  3. Wiring questions for heated seats
    By sal_park in forum 5 Series BMW
    Last Post: 09-24-2008, 09:33 AM
  4. 1990 Heated seats e34 Yes or No wiring information???
    By gmannino in forum 5 Series BMW
    Last Post: 10-30-2006, 10:40 PM
  5. Replies: 2
    Last Post: 02-09-2005, 01:27 PM
