Results 1 to 4 of 4
Thread: 95 540i 5HP30 Flush
    Jun 2006
    Default 95 540i 5HP30 Flush
    Hi all,
    I'm fighting with a dirty 5HP30. From what my mechanic says, doing a full flush could damage its sensitive electric valves. I'm thinking about disconnecting an oil cooler hose and putting it in a bucket. I'll start the car and pump new oil in through the fill hole in the bottom as the trans pushes the old fluid out the cooler hose. As long as I keep enough fluid in the pan (defined by BMW as fluid running out the fill hole) I should be okay. Right??? Any thoughts or suggestions are appreciated.
    Thanks!
    Paul
    What do you mean by "dirty"?
    A partial fluid change might be a good idea. I think flushing it, unless it's routinely been done, is a bad idea.
    follow the ZF program rules dude, only replace the fluid that drains out with the proper fresh fluid when you change the filter every 30k miles. Thats about 3~4 quarts and only use an OEM filter to reduce problems with leaky 'O' rings on aftermarket brands.
    Tampa Bay, Florida, USA
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
  1. 5HP30 (540i Auto Trans) Question...
    By MTechnik540i in forum 5 Series BMW
    Last Post: 10-29-2007, 08:35 PM
  2. E34 540i 5HP30 Questions
    By luckyguy19 in forum 5 Series BMW
    Last Post: 02-01-2005, 08:12 PM
  3. 94 540i transmission flush problems
    By Phil M in forum 5 Series BMW
    Last Post: 06-05-2004, 09:17 AM
  4. 5hp30
    By Ollie in forum 5 Series BMW
    Last Post: 03-20-2004, 08:20 AM
