did you refuel with engine running?
how do i reset this?
and also, why did it get stuck?
gas in function 6 seems to be right
my range is always WAY too high as well, take mpg * tank capacity and its like, half.
at 429km for d past few days. fuel is down to maybe half. or less...
normally... at this point, range is at 125-150km
is there a reset for this?
anyone?
Pull your battery cable for 10 mins. That should reset it.
www.universal5.com
Orange Tool Forum
San Diego, CA
1994 e34 530i Eibachs/KYB
0 miles on new windshield
Try looking through the TEST functions of the OBC, there is a setting to adjust the Range factor (some value stored that should automatically update depending on what car it is in, but most of the time is stuck at 100 anyway), maybe changing this value might reset the Range.
avg mpg and avg speed function is also out...
this might be the reason why range is mixed up.
speedometer is working mpg under the speedo is moving also...
can anyone guess what the problem may be?
My range function is pretty accurate. On pure highway I'm pretty sure i can get over 400 miles to the tank. I get 300-350 a tank with my highway/city driving to work.
When I first purchased my 1989 535i I had the identical problem. Recieved a lot of advice about resoldering and such. Sounded to much like a pain in the ass. Bought a OBC from ebay ($55 or so). It works great.
Would advise the same.
JMI
